CompTIA Linux+ Exam Questions
CompTIA
CompTIA Linux+
19 / 135
Question 19:
A junior Linux administrator is setting up system-wide configuration settings. The goal is to ensure the PATH environment variable includes the following locations for all users who log into a Linux system:
The administrator issues the following commands at the terminal:
Respectively, the output of these commands is as follows:
Given this output, which of the following would be the BEST action for the administrator to perform to address this issue?
A. Update the /etc/profile.d file using a text editor, navigate to the PATH element, add the missing locations, and run the bash_completion.sh script to update the changes.
B. Update the /etc/profile file using a text editor, navigate to the PATH element, add the missing locations and run the . /etc/profile command to update the changes.
C. Update the /etc/profile.d file using a text editor, navigate to the PATH element, add the missing locations, and reboot to update the changes.
D. Update the /etc/profile file using a text editor navigate to the PATH element, add the missing locations, and restart the bash process to update the changes.
