Question 42:
Which of the following configuration files should be modified to disable Ctrl+Alt+Del in Linux?
A. /etc/inittab B. ~/.bash_profile C. /etc/securetty D. /etc/security/limits.conf
Answer correct:
A
Reference: https://www.linuxtechi.com/disable-reboot-using-ctrl-alt-del-keys/
