CompTIA Linux+ Exam Questions
CompTIA
CompTIA Linux+
110 / 135
Question 110:
DRAG DROP - You have been asked to parse a log file of logins to determine various information about who is logging in and when. INSTRUCTIONS - Open and inspect the Login log file. Drag and drop the correct commands onto the output that was generated from that command. Tokens can be used only once and not all will be used. If at any time you would like to bring back the initial state of the simulation, please click the Reset All button. Select and Place:
