Question 55:
A Linux administrator implemented a new HTTP server using the default configuration. None of the users on the network can access the server. If there is no problem on the network or with the users` workstations, which of the following steps will BEST analyze and resolve the issue?
A. Run netstat to ensure the port is correctly bound, and configure the firewall to allow access on ports 80 and 443 B. Run route to ensure the port is correctly bound, and configure the firewall to allow access on ports 80 and 443 C. Run netcat to ensure the port is correctly bound, and configure a static route to the web to allow access on ports 80 and 443 D. Run route to ensure the port is correctly bound, and configure SELinux to allow access on ports 80 and 443
