Question 454:
A computer emergency response team is called at midnight to investigate a case in which a mail server was restarted. After an initial investigation, it was discovered that email is being exfiltrated through an active connection. Which of the following is the NEXT step the team should take?
A. Identify the source of the active connection B. Perform eradication of active connection and recover C. Performance containment procedure by disconnecting the server D. Format the server and restore its initial configuration
